unemployedav8er
New member
- Apr 7, 2006
SBD said:What are the chances of a newhire getting EWR out of training? My in-laws live 15 min away from EWR so I'll have a place to stay. Also how much influence does a walk-in resume play on getting an interview? Several of my old instructors are at XJT and we still keep in touch.
Weasil said:I will be commuting from ORD. CLE would be the easiest commute by the looks of it. Does XJ have a lot of ORD overnights out of CLE? Also, do you have long call reserve?
An interesting point of view considering we could all be out of a job by the 18th, be careful with your optimism, it might back fire.~~~^~~~ said:I see ASA as on the rise and Jet Express as in decline as a result of their own management. Chautauqua is growing like Kudzu and has the newest equipment. If I was a betting man, I'd bet on the airline with the E170's and E190's.
79%N1 said:ASA = Forever, and a day. Will be longer if we lose any SLC flying to Skywest, and if there is no growth coming with the ATR fleet being retired. Look at 5-8 years, depending on the above.
Midnight Flyer said:I can remember when I used to work for ASA and we first got the ATR's back in the 90's and they were brand spanking new. Seems like some turboprops and the barbie jets seem to have a definate life on them. I'm still on the b727 and there's no talk of retiring her.
sweptback said:It's not that ASA is retiring the ATRs because they're falling apart (although they somewhat are!), but because ATRs are in such high demand worldwide. Our leases expire in 2007 and from what I understand the new lease would be a substantial increase. Combined with the fact that we have so few of them, it doesn't make sense to keep them around.
Alchemy said:As far as the ORD commute, I flew with a captain a few times who did ORD-CLE for a few years, when CLE was downsized he went switched to ORD-EWR and then to ORD-IAH. He's switching back to ORD-EWR because he says the flight is a little shorter and it's easier to get home in the evenings.
He always takes a flight 7AM in the morning or earlier for his commute in, says it's just to risky otherwise when dealing with the combined delays of ORD and EWR. There are probably quite a few ORD/MDW overnights out of CLE, but on reserve (which is where you will spend at least a year if you get hired here now) you will have little to no say on where you overnight anyway. We do have long-call resrve, it is an 8 hour callout.
Weasil said:Alchemy,
Thanks for your helpful response. Is the long-call reserve something you can get straight away, or is that for people who've been on reserve for longer. We don't have that at PSA (where I work now). an 8 hr callout would allow me to sit reserve at home in chicago and then commute to EWR for a trip.
Baronman said:At this point at XJT Cleveland is not the place to be. While the other bases (EWR and IAH) are growing, Cleveland will continue to have fewer and fewer lines. We all fly so much though the other bases that EWR and IAH crews can pick up those CLE flights.
Pilot lines (roughly)
IAH = 500
EWR = 250
CLE = 110 (projected to become 80 by next year).
msuspartans24 said:these numbers are correct and as far as a long call line it looks like it is taking around 4-6 months.
Paul R. Smith said:Long call usually goes a bit more senior than short call. And when I say "a bit" its usually different for each base. CLE being the most senior, then IAH, then EWR... And BTW long call at xjt is 12 hours. When sched calls, you have 2 hours to call back, but 12 hours from when they call as a minimum. I had long rsv line call a couple of months back and I liked it but I don't commute. I just liked the flexibility of knowing I have at least 12 hours notice...It was almost like having a line or schedule...Almost.
