Excel Pilots
Choppy
Just wanted to pick the fractional pilots brains to see what their company's SOP is for starting the airplane with or without the APU? Flightsafety says the aircraft should not be started with the APU??? They say it can't handle it and causes trouble. Cessna tends to disagree!
Uh, FSI info is not accurate...XL can be started w/APU. battery, GPU or x-generator if one engine is already running. With APU running and it's generator on line, the starter receives it's power from the APU generator with the battery in line. One APU assisted start equals 1/3 battery start towards the 3 battery starts allowed per hour.
Why do you turn the avionics off w/ apu running for an engine start? Voltage spike? I always thought it was a funny set-up. It's the only cessna that I've flown that has an sop to do that.
Just wondering-
(PS- don't beat me up to bad for asking....I haven't flown an excel in 5+ years....)
Just wondering-
I've flown other aircraft that the avionics have to be off during engine start...I've tried starting the 560 w/avionics on and get all kinds of flickerings...then have to wait for realignment of HSI..not so on DA2000. I'll do a little research and get back to you.
Let me rephrase that... FSI says you will cause trouble with the APU if you start with it all the time?
gordon24 said:
Supposedly, all the NJA excels have been modified to start with avionics on. It's still old school in the checklist, so....
As of last week, I am positive that there are unmodified Excels in the NetJets fleet. :rolleyes:
Avionics
I was told that Cessna wants the avionics turned off as it was supposedly causing crt's to fail prematurely. We always turned the avionics off during start, but I would guess that it probably wouldn't necessarily cause a problem. This is Cessna protecting their warranty would be my guess.
During engine starts with a starter generator being cranked, voltage drops from the load. The avionics circuits unless shunted, would have to be affected by this drop. The DA2000, needing air to start, doesn't load the APU generator, using only the bleed air from the APU. Both FSI system texts, initial and recurrent, discuss engine starts utilizing the APU.
Hence, the use of the word "supposedly". I've found it depends on who you ask. I would say a majority of the folks I fly with turn the avionics off. One or two leave it on. It's in the checklist, so, I would turn it off. I'll play by the rules...saves me from getting spanked.
It's good to use the Nicad battery for a start occasionally...
Now what's this talk about getting spanked?
Flew an OCF that required a Honeywell Technician to ride along. We started the engines with avionics power on because our checklist says "Avionics Power - As Required". The tech had a fit because he said the power surges were harmful to the avionics. He likened it to rapidly and repeatedly plugging and unplugging your stereo/tv/computer when they were powered on. I showed him the checklist and asked if it was such a big deal, why not have Cessna write "Avionics Power - Off" in the checklist. He said it was because Cessna did not want to make it a requirement to turn off the avionics power off for engine starts. Since then I turn avionics off prior to engine start.
Supposedly this is true for the Excel and has been modified for the XLS.
It doesn't make a difference anymore at NetJets. Our new checklist has us turn the Avionics Power "OFF" prior to engine start....
Heck, we can't even start the engines until BOTH crew members are in their respective positions in the cockpit per a recent memo!!!!
