Since the FAA is closed today;
If an examiner is certified to do checkrides in a Pa23-160 does that allow him to give checkrides in a Pa23-250 ?
That's a Piper Apache vs Piper Aztec.
If not does that mean that a (succesfull) checkride will have to be taken again?
Thanks....
I believe the FAA requires examiners to have type specific authorization for multiengine a/c. Their examiner certificate should have the a/c designations listed. If it lists PA-23, then it would include Apaches and Aztecs. Otherwise if it lists PA23-160 and/or PA23-250, then they are limited to those a/c.
The examiner should know what they are permitted to test for.
Yes, but he is a bit of a cowboy, he might assume he's good for all Pa23's
while his listing on the FAA website only mentions Pa23-160.
He did get a couple of details wrong about the airplane on a recent checkride, not to mention a sim engine failure at 100' on a Private Multi checkride.
Not too smart in my book if he has limited experience on the airplane.
If he doesn't know, you are in trouble. They turn the paperwork over to the FSDO and it's reviewed by the inspector and again in Ok City, before the ratings are issued.
