FL420
Blues vs. Birds-Tailhook
- Oct 11, 2005
http://recruitingcenter.net/clients/evergreenaviation/publicjobs/controller.cfm?jbaction=JobProfile&Job_Id=10221
Unmanned Aerial System Pilot
Minimum Experience: 5 or more years of experience in a relevant functional area.
Responsibility: Perform Unmanned Air System technical and / or flight operations in various International locations. Responsible for Unmanned Vehicle pre and post flight system checks, and navigates the UAV to accomplish mission requirements. Must be thoroughly familiar with remote piloting systems, aerodynamic, and UAV flight performance operation parameters.
Minimum Education: Associates degree or equivalent military training and a commercial pilot’s certificate with instrument rating (or Airline Transport Pilot) and meets the qualifications for exercising these privileges.
Unmanned Aerial System Mechanic
Perform scheduled and unscheduled maintenance on unmanned aerial vehicles. Inspect at regular intervals: airframe, propeller and engine. Repair as needed fuel or oil leaks and engine problems. Remove and replace airframe components as needed including aileron servos, flap servos, brake servos, landing gear servos and throttle and waste gate servos. Perform all launch and recovery of aircraft including necessary inspections, starting engine, operational check, installing payloads (cameras, KU, Datalink, SAR, EO/IR), and fueling and de-fueling. Test, maintain and operate unmanned aerial vehicles and ground support equipment.
REQUIREMENTS:
Must have A & P license, but may substitute 5 years aircraft and engine maintenance experience. Must pass training course for Unmanned aircraft.
Desirable qualifications: Prior UAV crew chief or other UAV experience.
Varies. Must be willing to travel abroad for periods of up to 180 days.
REQUIREMENTS:
