For those flying the jungle jet, what are the dimensions of the kitbag slot in the cockpit? Do you guys recommend a lightweight headset, or the Mickey-Mouse headclamps? And finally, does CHQ provide guidance about acquiring this type of stuff during training? Thanks for any replies.
Any standard size flight kit bag will fit in the hole. The aircraft have David Clamp headsets already in them, but alot of guys use their own headsets. I would not recommend the lightweight headsets due to the noise.
I simply use my old David Clarks from my flight instructing days. I like that they are clean, already preadjusted, and have a windscreen on them (most company ones do not)
Office max sells a couple of catalog cases (flight bags) for less than 50...dont get the ones that have wheels, for they wont fit.
I have the cloth one. I paid 30 for it, and after 2 and a half years, it is time for a replacement.
Good luck... when do you start class? let me know..
"What makes the ERJ so loud? Wind noise? Can't be the engines."
The ERJ has the same nose and windshield as the EMB-120 and that design wasnt meant to go 450 kts. TAS without being noisy. Just poor aerodynamics up front. The noise isn't bad below 250 kts. but once you hit 10,000 and accelerate to 300 or so, you'll need the DC's.
The noise is caused by wind roar over the nose. When Embraer designed this jet (their first), they put a Brasilia nose on it. They didn't insulate it as well as they should have for the higher speeds.
Don't listen to FDBs like Bluestreaker. This is the real reason.
