Alert Engine failures at full aft throttle? Lycoming 363i
I posted on the CubCrafters forum to maximize awareness among FX-3 owners with Lycoming 363i and trying to learn what's causing full aft throttle engine failures I'm hearing from friends having this issue. I don't know if it's idle mixture or idle stop with RPM too low but hope to learn. Posting so others can follow or add to the discussion.
The Lycoming 363i is a modified/experimental version of the Lycoming IO-360 fuel injected engine.
