Embraer Headset
Master Shake
Number 1 in the hood!
I've run a thread search for headsets but I didn't see what I was looking for. So I am here to ask present and former ERJ pilots what they used for headsets. I've been using my own old school DC's and the time has come to downsize. What I want is something like this:
http://www.headsetsetc.com/mach1headset.html
Can anyone recommend some good headsets like this? That ERJ is noisy and I'd like the new headsets to cut out as much of that wind noise as possible. I'd also like the ability to hook my ipod in directly.
I haven't seen too many people rolling around in those type of headsets above in the ERJ. I'm using the bose, it hurts for 12 months with the payments but whatever. It is a vast improvement over the DC vise grip.
I'm using the Bose, and have no complaints. They are quiet as can be, just make sure to shut off your hot mic (and hope the capt. does as well) and all you'll hear is the sweet sound of silence. They are also good at getting rid of the annoying PPG window crackling noise in the XR's:)
tjsatter said:
Is the IPOD approved for cockpit use by your company?
tj
No, but then again neither are all of the books and magazines the Captains read. What's your point?
Really? I have no knowledge of such a thing. The Captains at my company never read unnapproved materials in flight nor do they use IPODS or other entertainement systems. When flying their full undivided attention is addressed to the plane and systems. When not flying they monitor the radios and navigation systems. There is never any irrelevant conversation below 10k. The point is I do not know how or if an IPOD can be connected to any headset in flight. What outfit are you at?
tj
An ipod or other media device can be connected to the headset that is linked in my original post. I've also heard from several other captains that other headsets like this exist. My primary concern is good sound quality and cockpit noise dampening. The ipod thing is a bonus at this point.
Master Shake said:
What's your point?
The point is to think about what that last few minutes of the CVR would sound like to your family and passenger's loved ones.
On the headset question....Telex 5X5 Pro III with custom earmolds and 6 filters with the gain properly adjusted.
And just recently an FO showed me a trick using rubber pencil grips sliced into rings that gives probably an extra 5-10 dB in noise reduction all in the frequency generated by the shock wave above your head.
Thanks for the feedback. My music has never made it onto the CVR as I use ear buds. The headset I linked to indicates that your music is piped in your headset only. That's what I want. I would not want to use any device that pipes it into the CVR for the very reason you stated.
tj
Trans States is where I got my first adapter. Many a Capt. had one and used them all the time. Wasn't anything is the manual about not using it then, don't know about now.
Guess people just know not to bring theirs out around you.
Guess all those AM radio stations on the ADF are so much different. Nobody listens to those.......
I just bought the Mach 1 in the link above. It is supposed to arrive in a couple of days. The lightSPEED Mach 1 headset provides 29dB of noise reduction. The David Clarks that my company provides are only 23dB. My old Telex ANR 500 was only 24db when I have a good battery in the module. So you should have plenty of noise reduction. It only weighs 1 ounce. I don’t see how you can go wrong with this headset. Sounds like a winner to me. I will try to reply again in a week or two when I get a chance to use mine in the ERJ.
I used to have the Telex ANR 500. It worked great in the CRJ. Most of the time we took our headsets off out of FL180 anyway.
The problem in the ERJ is that the Telex 500 picks up a LOT of the wind noise through the mic when the intercom is selected on. I have tried other headsets and most of them did not relay this loud noise when the hot mic was on.
A
s far as the music thing in the cockpit, some people on here are just too simple minded. The "cable" that people speak of started out as a cable that allowed you to hook up your music listening device to the intercom and listen to a little elevator music during cruise. BIG deal. But then the CVR issue arouse so many decided to opt for the new "cable" that allows you to listen to your crappy elevator music ONLY on YOUR headset and NOTHING is heard by the other pilot or the CVR. The MACH 1 allows you to plug your cell phone or music device directly into the headset without this “cable” so that you can have a little peaceful music on in the back ground to drown out some of that god awful wind noise the ERJ on those 3 hour legs. If something very important comes up I am sure the person would then turn the music off and deal with the problem, at least I would. If you were listening to the "big game" over the ADF and had an emergency would you just leave it on all the way down or turn it off and deal with the problem?
I don't see why listening to a little music during non sterile times is a problem. These new headsets allow you to hook your CD player or MP3 player directly to the headset for that reason and the cable that allows you to hook up your players to the older headsets, that do not have this built in, are sold at many pilot shops. I bought mine from Sporty's.
SayAgain! said:
As far as the music thing in the cockpit, some people on here are just too simple minded.
Well, you have to understand that 100% of the guys that I have flown with that wanted to listen to music in the FD did not have the set up where it only went into their headset, it went throught the ICS and into both headsets and CVR. So I go with what I know.
If one wants to listen to music, fine. But I don't want it recorded on the CVR or distracting me from reading my um........manuals :D .
But the second one starts missing radio calls or reading back clearances incorrectly, then "professionalism" and "general attitude" begin to come into question regardless of whether anything is recorded on the CVR or not.
I've got lightspeeds and the interface box has a small cable that goes to an IPOD or cell phone or any other distracting device. Traffic on the radios or intercom mutes the music. This is nice but an FO who hums shuts off your music ;-)
I use the Telex Airman 750 with earplugs. Much more comfortable than the DCs for those 3 1/2 hour "regional" legs we do.
SayAgain! said:
I just bought the Mach 1 in the link above. It is supposed to arrive in a couple of days....Sounds like a winner to me. I will try to reply again in a week or two when I get a chance to use mine in the ERJ.
Please post how it works. I've been very interested in this headset. If it works well for you in the ERJ, it might be a nice early X-Mas present for me. Thanks.
I will, but it may be a couple weeks. I bought it 3 weeks ago but LightSPEED has not shipped them off to the the stores yet. I was told it should ship from Sporty's some time this coming week.
Lightspeed Mach 1
I just received the Lightspeed Mach 1 in the mail today. They were just released. I will have a chance to try them in the next day or two and will advise my findings. They are the lightest out there that I have found.....even compared to the "Clarity Aloft." If the sound quality is what they claim, it should be a good unit.
I got my Mach 1 on Monday. I was able to try it on this trip. It's awesome. I did a comparison of my molded telex earpiece vs. the mach 1. The Mach 1 wins hands down. it's quiet, comfortable, drowns out all the wind noise and the mike is quiet. It's a clear winner.
Ditto-what he said-the Mach 1's are the missing link for the ERJ!! Downside=Mic is a bit short, I'm trying to get Joe at Lightspeed to lengthen the mic 1" at least for better sound quality. What do you guys think that are using the Mach 1?
So far I like mine a lot too. I think the mic could be a little longer but it is nice not having to move the mic out of the way to take a sip of water. One thing I wish I could do is put the mic on the right side. That way I could put that side on and leave the left ear piece out while taxing when the guy in the left seat does not have a headset on.
Does any one know if you can get a custom ear mold for this headset? Just wandering if I can can cut even more noise out if so. The documention that came with mine is lacking. What is the button on the opposite side of the volume control for? Which direction do you put the bigger ear piece on in. With the tube extended out or in?
Is $500 a stretch for you? It normally would be for me but I sold my telex 500 that I bought 4 years ago for $420 new from the old company store and had it pay-roll deducted until a few months ago. I sold it on eBay for $350. So I only had to come up with the extra money. If you can unload your old headset on eBay then it might help with the price. It doesn't matter the condition. At the same time I also sold an 8 year old pair of David Clarks that had fadded to a yellow green, worn out and was sitting on my basement tool chest for the last 5 years for $98.00. Otherwise, no I would not have dropped $500 on this headset.
With that said, I would highly recomend this headset for the ERJ or any other aircraft. I have Jumpseated in many different aircraft and the Mach 1 would would be my first choice if I were flying anything different. I used to have to sit up front in a Jetstream also to commute. I think this headset would work fine on that aircraft too. I don't know how the noise levels compare on the J41 with the Saab or the Beech's, but I am sure they are similar.
FYI, the headset comes with a 5 year warranty with LIGHTspeed.
ERJ and Mach 1 Headset
Bump ---
Just curious how is the hot mike noise in the ERJ with the Mach 1? I have been able to adjust my Telex 5x5 down to a good level but I am still in pursuit of a better headset.
hot mike noise is not a problem for the mach 1's. I got rid of my bose X for the mach 1's. They are worth every penny. Funny though, I've only been able to use the blue ear plugs that came with them. Tried the white ones & they were worthless (made of rubber). I guess it'll be a good idea to stock up on the blue ear plugs before running out of them.
