I have a 1978 Tiger AA5B with anengine mystery that I hope someone can help me with.
In March, I had my annual inspection with no surprises. The mechanic suggested that I replace the spark plugs so I gave the go-ahead and asked that he use fine-wire plugs since that what the plane had for the past several years with no issues. On my first flight after the annual, I noticed that the EGT in cylinder #3 was running higher than normal. I went back to the mechanic but he could find nothing wrong. Since the difference was not too severe, I did not worry too much about it. Last week, I started having a rough mag check so I went back the mechanic. He cleaned all the plugs and the mag check seems better (although not perfect)....but now my EGT problem is much worse! Cylinder #1 reads lower than usual and cylinder #3 reads higher than ever. The difference between the two EGT's exceeds 200 degrees so it triggers the alarm on my engine monitor.
Somewhat frustrated, I went to another mechanic. The new mechanic found a crack in the intake pipe leading into cylinder #3 so I was ecstatic that the problem had been resolved! A new tube was installed and I picked up the plane for the flight home. However, the EGT problem is unchanged!
So, here's my plan:
Step 1 - I'm going to swap the probes between cylinder #1 and #3 to eliminate a probe issue
Step 2 - I'm going to swap the plugs from the left side to the right side to eliminate plug issues
Does this sound like a good approach? Am I missing another obvious possibility? It's odd that the problem started with the installation of new plugs and got much worse when these same plugs were cleaned! Could a plug be causing this and eluding two mechanics?
Any ideas or suggestions?
Thanks!
Greg
So, here's my plan:
Thanks!
Greg
