uwochris
Flightinfo's sexiest user
- Dec 21, 2001
Hey guys,
I have another Q regarding mixture control, and I hope I can get some feedback.
In one book, I read the following:
" An aircraft's engine will run hotter with a lean mixture than with a rich mixture because the leaner mixture is slower to burn, exposing the cylinder walls to higher temperatures for longer periods of time. A richer mixture will burn faster, exposing the cylinders to high temps for a relatively shorter period of time."
What do you think about this?
I always thought that the leaner mixture is burning faster, and this speeds up the combustion cycle as more heat is produced, and more work is being done.
Also, I read that as you lean, the mixture begins to burn faster, and the Peak Pressure Point (PPP) will occur closer to Top Dead Center, resulting in higher pressure and higher temps- this is the direct cause of the high CHT with a leaner mixture (assuming you're not lean of peak). This seems to contradict what I read above.
What am I missing?
Thanks in advance.
What am I missing?
Thanks in advance.
