DME arcs
CloudyIFR
Active member
Can ATC vector an aircraft onto a DME arc in a radar environment anywhere upon it's length?
Can ATC vector an aircraft onto a DME arc in a non-radar environment anywhere upon it's length?
What is the maximum turn in degrees that you're allowed to turn upon an arc?
Here's an approach with DME Arc's.
http://204.108.4.16/d-tpp/0602/00192I27.PDF
So if I'm inbound on the 053 radial can I turn left onto the arc then proceed inbound on the ILS in a radar environment? How about in a non-radar environment?
From what I've been hearing lately from the Part 121 guys is that the only place to enter a DME arc is at the very end. Okay, I think I understand that intercepting it anywhere upon it's length won't guarantee the TERPS descent gradient. Fair enough.
However, if I'm inbound on the 053 radial say at 30nm and wish to fly the arc and request direct to the HLN 336 radial at 15nm with my trusty RNAV, when I arrive there I'll have about a 180 degree turn to get onto the arc. Depending on the airplane I'm flying, i.e. groundspeed, I may not stay in protected airspace during the turn but once I get turned around I'll maintain the descent gradient for the approach. But wouldn't it be much safer to turn onto the arc at the 053 radial since it's only a 90 degree turn, I'd still have plenty of time to make a normal descent to the altitudes on the arc.
I realize I could just come to the VOR then out to the end of the arc but I'm trying to understand fully why I can't join the arc anywhere upon it's length if I decide as the Capt that I can provide normal descents onto the arc and the approach.
I hope I wrote this clearly enough to start a nice discussion about this.
Of course any references would be nice.
CloudyIFR
Nov. 28, 1994
Mr. Tom Young, Chairman
Charting and Instrument Procedures Committee
Air Line Pilots Association
535 Herndon Parkway
Herndon, VA 22070
Dear Mr. Young
This is a clarification of our response to your letter of August 23, 1993. In that letter you requested an interpretation of Section 91.175 of the Federal Aviation Regulation (FAR) (14 CFR Section 91.175). You address the necessity of executing a complete Standard Instrument Approach Procedure (SIAP) in a non-radar environment while operating under Instrument Flight Rules (IFR). Our response assumes that each of the specific scenarios you pose speaks to a flight conducted under IFR in a non-radar environment.
Section 91.175(a) provides that unless otherwise authorized by the Administrator, when an instrument letdown to a civil airport is necessary, each person operating an aircraft, except a military aircraft of the United States, shall use a standard instrument approach procedure prescribed for the airport in Part 97.
First you ask whether an arriving aircraft must begin the SIAP at a published Initial Approach Fix (IAF). A pilot must begin a SIAP at the IAF as defined in Part 97. Descent gradients, communication, and obstruction clearance, as set forth in the U.S. Standard for Terminal Instrument Approach Procedures (TERPs), cannot be assured if the entire procedure is not flown.
You also ask whether a Distance Measuring Equipment (DME) arc initial approach segment can be substituted for a published IAF along any portion of the published arc. A DME arc cannot be substituted for a published IAF along a portion of the published arc. If a feeder route to an IAF is part of the published approach procedure, it is considered a mandatory part of the approach.
Finally, you ask whether a course reversal segment is optional "when one of the conditions of FAR section 91.175(j) is not present." Section 91.175(j) states that in the case of a radar vector to a final approach course or fix, a timed approach from a holding fix, or an approach for which the procedures specifies "no procedure turn," no pilot may make a procedure turn unless cleared to do so by ATC.
Section 97.3(p) defines a procedure turn, in part, as a maneuver prescribed when it is necessary to reverse direction to establish the aircraft on a intermediate or final approach course. A SIAP may or may not prescribe a procedure turn based on the application of certain criteria contained in the TERPs. However, if a SIAP does contain a procedure turn and ATC has cleared a pilot to execute the SIAP, the pilot must make the procedure turn when one of the conditions of Section 91.175(j) is not present.
If you have any questions regarding this matter, please contact Patricia R. Lane, Manager, Airspace and Air Traffic Law Branch, at (202) 267-3491.
Sincerely,
/s/
Patricia R. Lane
for Donald P. Byrne
Assistant Chief Counsel
Regulations Division
Dang avbug, where do you find all these interpretations? Where I work we're always talking about these beasts, but can never find them. You pull them out like you've got a stack of them on your desk.
Seriously, is there a central place to find these things, or do I have to keep stumbling across them here and there?
I used to have fantasies about being educated by nuns.
I don't work. That's a misconception. I get paid, but I don't work.
If you get ASA's Flight Library (the pro edition), you'll have all FAA pubs and a bunch of manuals and books all on one CD, for eighty bucks. Same one the FAA uses. Makes searches fast, copying information quick, and saves having to lug around a bunch of paper. Although in honesty, I prefer paper. The more I write in the margins, the less I can see of my computer screen. Presently the viewing area is about the size of a matchbook.
Satpak, I fly, but you're the first to call this wreck of mine a "career." Thank you, anyway.
Not a stack of them...just a reference CD (and update subscription) issued by this company:
http://www.summitaviation.com/
(Of course, you have to have nothing better to do with your time than look this stuff up, then copy and paste on message boards such as this...;) )
Thanks avbug and flx757, I didn't know such a disk existed. Very helpful. I feel an aviation-related expenditure coming on.
Ok, maybe it's me, but that whole paragraph is either poorly written, or I have had way too much Mexican food this weekend. I get the meat and potatoes of it, no intercepting an arc anywhere but the beginning. But the feeder route reference throws me off. A little enlightenment maybe?
http://www.naco.faa.gov/d-tpp/0602/05187VG17R.PDF
There are no feeder routes to the arc. How is one supposed to get to the beginning, assuming no GPS or RNAV unit (I know one in the same). You could fly to the VOR and then fly outbound on either the 071 or 269 radial, but what's the point? If you do that just go outbound on the 003 radial (which is a feeder route to blits). I do know that there is a victor airway that runs through the NE section of the arc on about the 020 radial or so. Other than the Avbug's letter, why not, if you are inbound on that victor, simply intercept the arc and fly the approach from there. I know I know, because the Admin said so, I get that, but operationaly it makes no sense.
Now, that letter was written in 1994, a bit before GPS was making a big showing, especially in the instrument approach world. Every GPS unit, even FMS units, have the ability to "move" the arc. Bendix units will redefine the IAF to be the point on the published arc that your current ground track will take you to. It will only do that if you are on a ground track that will intercept the arc on a published portion. Garmin units simply activate the whole arc (make it magenta). What I don't get, is if you are not allowed to intercept the arc anywhere but at the published IAF, why do these FAA IFR/APPROACH approved units have that function built in and have instructions on how to do it. I realize that is in no way the FAAs way of telling us pilots that we can intercept arcs anywhere, but it is a curious "thing".
I realize ATC can vector us to an arc, and maybe that is what the function is for in these GPS units. Anywho, off to find more Mexican food....
avbug said:
Arc's aren't just used for approaches.
Arc's may also be part of a feeder route.
I gues I have never seen that (doesnt mean it doesnt exist, just never seen it) I have seen an approach that is one continuous arc to the runway.
I am wondering if the person that wrote this letter misunderstood what was being asked, although I am not privy to the actual question. It would seem that if the FAA didn't want pilots intercepting arcs anywhere but the IAF on the arc there would be an easier way to answer the question. Or maybe I just have too simple of a mind.
Do you have any examples of an arc being part of a feeder route, that would be interesting to see. Also, any opinion on the GPS units being able to move the arc?
So AVbug what you're telling me is that in the case of the HLN plate if I want to get on the arc and I'm coming from the East then I'll have to make a 180 degree turn and the end of the arc and that would be legal to do?
Thus if you like burning up time and fuel if coming from the East then the arc is worthless.
Thanks for everyone's input.
CloudyIFR
PS By the way, the USAF TERPS allow you to enter wherever you like as far as I can interpret. I was never a USAF pilot, only an avionics tech, now retired and living the dream!
Unless otherwise stated or given instructions from the controller, the ARC may be intercepted from anywhere. At a distance = to 1 to 2% of your groundspeed (150KIAS = 1.5-3.00NM), turn 90% and intercept the ARC. If you have an RMI, just turn 90 degrees and keep the needle pointed 90 degrees to your direction of travel. If you are getting blown towards the fix the ARC is based off of, put in some correction and if you are getting blown away from that fix, once again, put in correction. It really is just that simple. DME ARCs happen to be a great place to use the A/P in HEADING mode.
On the airways. To OTEJE via V191 from the Thief River Falls VOR and the OTAXY on V430 from Devils Lake VOR
What if you're coming down V171 from ROX VOR and 30 miles out you go direct to OTEJE, can you make the approx. 150 degree right turn to the arc?
I just don't see why that if you're at the MEA of 2,900' you just can't stay on the airway to the VOR and intercept the arc. Yep, you'll be 400' high but if you can easily lose that altitude. Also, isn't it safer and more likely to stay within the protected airspace of the arc making a 90 degree turn onto the arc versus 150 degrees? All depends on the gruondspeed.
Also, if ATC says, cleared for the approach via 12DME arc they will not expect you to go to OTEJE, they'll expect you to go to the VOR till joining the arc there.
Seems there's a disconnect from the Chief Counsel, the FAA, the USAF and pilot's in general.
Thanks for the nice discussion and staying on topic.
Me
Thank you for acknowleding that fact. The Chief Counsel got there by not answering operational questions. He's a lawyer. He/They know how to legalspeak; they answer a question about a rule/procedure, and they answer with the exact same words in that rule/procedure. They are not gonna tell you that you can cut a corner, no matter how safe and practical it is.
They (the FAA) are not gonna come after you either. They can only come after you for violation of a regulation. Find the regulation that you can be violated with and you will have your answer.
Okay, I'm going to own up to my lurid distant past: I once was an air traffic controller, and once upon a time I worked in a NON-radar approach control tower. Back in the day, DME arcs were used all the time at such places for the very reason we've been discussing: no PT's. (Arc transitions can be time-consuming, though.)
I can tell you it was common to allow arc intercepts inside the IAF; even an off-airways intercept can be positively positioned by asking the pilot to report the radial he's crossing on the arc.
Once established on the arc, inside the IAF, you are on a published segment of the approach. As a controller, I'd have been flabbergasted if a pilot had asked to return to the charted IAF on the arc and make a 180. I mean, WTF, over??
I don't know what planet that FAA opinion-writer flies over (if he's a pilot at all), but it's not Earth.
Somewhat off-topic: when a radar is finally installed in a non-radar terminal area, it turns for some time before it's commissioned for ATC use. You should see what pilot nav really looks like sometimes -- it would scare the hell out of you. Holding pattern entries? Hahahahahahaha ...
It may not be earth they're flying over, but it's on earth that the FAA Chief Legal Counsel will oppose you during the appeal process following enforcement action...and the legal interpretation is the teeth to do so. Disconnect or not.
Reality, vs. not.
Lots of pilots live with their heads in the clouds under the blissful assumption that the Administrator has better things to do than violate them for what they consider trivial humdrum. I can tell you from personal experience that is definitely not the case. For many inspectors, it's their entire purpose for being.
I know an inspector who violated a pilot for this very thing; failing to fly the full proceedure. He happened to be at KJAC when he saw the pilot do it and then proceeded to approach the pilot on the ground after he landed. Busted. (It wasn't an arc).
Did he violate six airmen, or was it just five? He honestly doesn't know, himself. But you gotta ask yourself one question. Do you feel lucky, punk? Well, do ya?
That's too much work. If it's a charted DME ARC and you're cleared for the approach, LNAV/VNAV do wonders.... Puerto Vallarta VORDME 22 comes to mind... :D
I might be looking at an old chart, but V430 is off the 270 radial, and according to the FAA I would have to be on the 269 radial, or 1/5 of a mile to the south, to legally start the approach. V191 is off teh 071 radial so if I was inbound from TVF, no prob, but if I was inbound from ROX on V171, I have to either track to the vor and then outbound on either the 269, 071 or the 003 radial to start the approach, or get radar vectors if available. Makes sense to me.
I saw that to. I wonder if it's just because the VOR needs an update due to Mag Var change or not. Wonder what the Lat/Long are for the two points as they may actually be the same point but time has required some adjustments.
Thanks everyone for the nice thread.
All and all, we are splitting hairs, non radar, start the arc at the beginning to be legal, vectors, go wherever ATC tells you (yes yes, dont let ATC kill you).
Keep in mind, mag var will not change a VOR radial, it will only change the mag course across the ground. The radial is "fixed" and has to be manually "recalibrated" if thats the right word.
I used to teach at this airport. MTN in Baltimore, a continuous arc approach.
http://www.naco.faa.gov/d-tpp/0602/05222VDTZ15.PDF
Ah! The Martin State arc approach. A favorite for a session on a sim!
jeez you guys are making my head hurt with all that tech jargon stuff
I don't think that there is a better one for training than that one. Log after I had my Inst ticket, I worked with a corporate pilot to actually learn something about real world flying. He had a PC Training device that was FAA approved. He would have you shoot the Martin State full ARC and he would change the speed and the direction of the wind everytime I progressed 10 degrees. You wanna talk aobut wondering how you ever passed a checkride! When I finally figured out what he was doing, I was already well on the way to mastering that bad boy, but it did teach me alot, and I have no problems when given an ARC to this day. I think they are a challenge and a lot of fun. Now if only I could get a trip to the Baltimore area.
Well I kindda feel like a dumba$$!!! I have no idea how to do a dme Arc. so this discussion is kindda depressing!!!! lol
