apcooper
Dude, where's my country?
- Sep 4, 2004
I've noticed a lot of the early model Apaches and Aztec's only have one alternator and one Vac pump which make me think that the engine failure checklist could actually mislead you if your flying in IMC and you lose the engine that the vac pump is on. If you feather the prop then in addition to losing the engine you also would lose vac suction and therefore in IMC you would be flying single engine partial panel. If seems to be in this case it would be better to have a windmilling prop and accept a very slow driftdown since the windmilling prop probably could provide sufficient vac pressure. Am a going wrong. Have any of you ever thought about this or even had it happen. This seems like arare example of when following the checklist would hurt instead of help?
