groundpointsix
- Jan 28, 2003
Here's my situation:
Yesterday I filed for an IFR flight into Cleveland Burke from my home airport. Good VFR conditions prevailed, but I decided to file simply because I was going into a class B area which I was unfamiliar with. When I called approach control at my home field to pick up my clearance (we get our clearances through an RCO) I was told that my clearance hadn't shown up on his computer and to give him a call back in 3 minutes when the strip should show up. (I was a few minutes ahead of my filed time, though I haven't had that happen before) When I call him back he says he still doesn't have my strip and asks me for some more information so he can call flight service for me. (Huntington approach always goes out of their way to help pilots out, certainly more so than a lot of other facilities) He comes back on and tells me that flight service doesn't have my flight plan either, but that he can give me a flight plan direct to an NDB near our field, then direct to Cleveland. I accepted the clearance, fully expecting that I'd be given a full route clearance from center once I checked in with them. (They did give me a full route clearance) Here's my question: Did I screw up by accepting the direct routing clearance since I only had a VFR GPS onboard, or was it understood that since i was /U that I would have to be given vectors or a full route clearance once airborn? Is this something I should file a NASA report for? I admit I should have questioned the clearance when he gave it to me, but at the time it didn't occur to me.
Thanks All
Thanks All
