Isn't it something like the best you can do as far as rate (not talkin Vy) of climb/descent until within 1000' and then 500-1500fpm?scubabri said:can anyone provide the reference for what descent rate to use when ATC asks you to decend and maintain?
thanks.
sb
minitour said:Isn't it something like the best you can do as far as rate (not talkin Vy) of climb/descent until within 1000' and then 500-1500fpm?
-mini
Flymach2 said:Hi...
Chapter 4, Section 4 of the AIM.
"When ATC has not used the term "AT PILOT'S DISCRETION" nor imposed any climb or descent restrictions, pilots should initiate climb or descent promptly on acknowledgement of the clearance. Descend or climb at an optimum rate consistent with the operating characteristics of the aircraft to 1,000 feet above or below the assigned altitude, and then attempt to descend or climb at a rate of between 500 and 1,500 fpm until the assigned altitude is reached. If at anytime the pilot is unable to climb or descend at a rate of at least 500 feet a minute, advise ATC. If it is necessary to level off at an intermediate altitude during climb or descent, advise ATC, except when leveling off at 10,000 feet MSL on descent, or 2,500 feet above airport elevation, (prior to entering a Class C or Class D surface area), when required for speed reduction."
Regards
Don't assume that optimum rate means (as minitour stated) "Isn't it something like the best you can do as far as rate (not talkin Vy) of climb/descent until within 1000' and then 500-1500fpm?"Flymach2 said:Chapter 4, Section 4 of the AIM.
