SennaP1
Livin' the European Dream
- Jan 26, 2002
The only place I see where "legalities" and VDP are used in the same published context is: 121.651(c)(4). I believe it applies to those approaches which "incorporate..." a VDP. This seems to mean contain a published VDP. I know NOTHING about 135.SennaP1 said:So when is it "legal" to descend out of MDA
Just base your descent on the profile 300 feet per nautical mile. If you have to, set up a ratio of 300:1 to your height over "n" (VDP distance).MikeSF340 said:Was just wondering how to calculate the VDP. Thanks for all the help.
Mike
This raises another question – should we always be able to land if the weather is at minima? Procedures may often be designed at at desk far away by a person who is just looking at the numbers recorded by surveyors. I know several non precision approaches where the pilots who frequently fly there would say that you can forget to land there safely when the visibility is at minima.Keep in mind that many VDPs are greater than one mile from the runway, yet many non-precision approaches have one mile or 1.5 miles visibility minimums
just use the HAT (height abv tdz) /300...Mel Sharples said:Just base your descent on the profile 300 feet per nautical mile. If you have to, set up a ratio of 300:1 to your height over "n" (VDP distance).
For example, let's say your MDA is 550 feet:
300 x 550
..1..... n
300n = 550
n = 550/300
n = 1.83
So your VDP is 1.8 miles. So start your descent at 1.8 miles and you are fine. I'm sure there are other methods but this one is quick and easy.
Good luck...
