Delta Reserve question
cargoflyr69
V-Dub for Life
How does one bid for golden x-days now that the january award is official?
I was wondering that also. I'm a line holder & can't find the link in ICREW. Is it different for Line Holders vs. Reserves. Thanks.
Go to Bids in icrew, then select initial bids then the last item is"Pbs reserve golden day bids". Select that and then rank your days. It should list the X days on your schedule. Remember you can only have two blocks of X days beginning with a golden day. Hope this helps.
Thanks a bunch!
Now how about swapping reserve days with yourself. Is that possible thru icrew or do you need to speak to a scheduler? the 2 days I want to swap around look like they have 3 times the minimum reserve coverage so hoping its possible and not to be a prob.
Go to PCS
Request Time off
Reserve Days
DO the swap
MAKE SURE YOU ARE IN THE CORRECT MONTH WHEN YOU GET TO PCS.
How does the PCS system notify you that the change was made? If it can't or won't make the trade does it tell you of a denial and why? Can you ever get satisfaction by talking to a human scheduler?
Look in the Pilot Leave Request Menu
At the bottom, choose Display Status of Leave Request
Or just look on your Future Schedule
