It depends upon which equipment you're talking about. Certain "anti-ice" equipment is turned on, on the ground, prior to takeoff, rain or shine, day or night, summer or winter - pitot and static port heat and, in some aircraft, windshield heat (Strenghtens windshield for bird strike protection.)Mtnjam said:Does anyone know when it is required or recommended to turn on De-Ice Equipment when you have Visible Moisture, meaning temperature's? I'm curious of the Highest and lowest Temps.
You showed me.Lead Sled said:Show me that in any flight manual.
Dang good question. Also a question that illustrates the reasons why I'll never be a true genius, because I'd never even thought of it. Oh well.Peanut gallery said:Is not ram rise changing the saturation rate relative to the actual temp and making higher moisture levels changing the logic? It just seems like a hole in the process.
