Why do you roll forward at first before you start backing up? Is it just what happens when you take the parking brake off?
340drvr said:Unsticking and getting off tire flat spots, yes; Momentum? No. Go back to freshman physics, conservation of momentum, there's no way it takes less steam to reverse direction of travel and start moving the other way.
The buckets are hydraulically actuated and could even deploy with the engines shut down.Propsync said:I thought they moved forward first because you have to spool the engines before you can send the buckets.
TWA Dude said:The buckets are hydraulically actuated and could even deploy with the engines shut down.
Jeff Helgeson said:Okay FLX757, put off that intercompany memo and break out your manuals, but don't spank me if the limitatoin was 10kts!
Jeff
Jeff Helgeson said:In addition, the MX manual and GOM (POH) states to start the engines with the buckets deployed if there is a tail wind greater than 20 knots.
