Cross Country planning question
  • Thread starter Thread starter BoDEAN
  • Watchers Watchers 4
BoDEAN
Cabo Wabo Express
How many of you have your students list a Top Of Climb and Top Of Descent checkpoint on their cross countires?
My policy at my new job requires a T.O.D, which is something new to me (never had a student calculate that in the past....)
...exactly how do you determine descent fuel burn? Am I looking in the wrong part of the POH? I'm able to find climb and cruise but not descent...
-mini
-mini
Some of the newer piper pim's had speed, distance, & fuel burn to decend. I've only come across them in some of the new pim's.
I used it for a 00 arrow.
I teach it to all of my students. It's not really necessary but it helps those students who just wouldn't start a descent from 5500 AGL until they were 3 miles out. Makes them think a little bit more. I doubt any students ever use TOC again if they don't go on to get a commercial.
Mr. I.
Never had it taught to me in a piston airplane, never taught it to any of my students.
I wasn't taught it, but really wish I had been. It's much less work to do it on the ground, ahead of time, than to be trying to figure it out while you fly, look for traffic, pick up atis, pick your nose, etc. Workload is even higher when you don't have some means of precisely measuring distance and groundspeed. (I didn't say it was hard, just that it's a higher workload before any of the anti GPS purists flame me) Besides, it just prepares the student for what they're going to have to do anyways when they get into higher performance airplanes. That being said, I still don't do it myself, but that's more because the airplanes i fly are generally equipped with a GPS and I have the experience now to do it on the fly anyhow.
If you figure out your power setting for descent, look at the cruise chart and you'll get a ballpark figure for the percent power that setting used as the associated fuel burn.
Not that precise, but neither are the climb numbers in most single-engine manuals.
As to Bo's original question, I don't worry too much about that TOC. But I do ask my students to calculate how far out they will need to start descending in order to have a comfortable 500 FPM descent from cruise to the pattern, and to choose a nearby landmark.
Patmack18 said:
(a simple one) i.e. 360kts g/s = 6 miles per minute... from 25,000 down to 1000' pattern elev. @ 2000 fpm = 12 minutes... so 12 X 6 = 72 miles out to start your descent... it's simple (hope I didn't fuk up the math!)
There's no reason for a student NOT to compute this
There isn't, but I really want to see that 200 FPM 360 KT descent in a single engine piston trainer. :D
Rule of thumb we us is Altitude divided by two = miles out to start the descent.
Example.
6000 feet
half of that is 3000, drop the as two digits.
30 miles.
Start you descent at 30 miles at about 500fpm and it works out nice.
Example.
6000 feet
30 miles.
haha...in what?? Lear maybe? 90kts groundspeed hmmmm I lose my 3000 ft in 6 minutes and I'm still 21 miles out. :)
Well there's enough "hot doggin" instructors out here that have shown me some cool stuff...
...like if you're really in a bind, just put it in a slip from 10,500...you'll be down to TPA in no time...the really "bad ass" guys just spin it...they get down the fastest...
Seriously though...thanks for the help guys...I've got a flight in about an hour and I'll work on the descent planning.
-mini
yeah, sorry. Thinking a 180kt cruise descent at 3nm per minute. You will need to cut by 2/3 instead of 1/2 if your only moving at 1.5nm/min.
Or calculate descent time interval in minutes at a convenient rate eg 500'/min then start the descent that many minutes (+ a few extra for speed reduction) prior to ETA. Saves mucking around with calculating distances from groundspeed.
500'/min is easy because descent time in minutes = 2 x 1000's of feet to descend. 300'/min is OK too. It approximates 3 mins per 1000's of feet to descend, or 10 mins / 3000' descent height.
