F
fokkerjet
I have a question on some crew duties during an emergency evacuation, specifically, what does your airline consider as being the "primary" exit(s) and which are considered to be "secondary", and which crewmember covering which?
On airplanes equiped with both an airstair door (door L1) and a service door (door R1) located in the front of the aircraft, and one emergency exit overwing on each side of the fuselage, will your "primary" exits be L1 and R1 (or just L1 or just R1), with the F/A guiding the evacuation from somewhere near that position and your "secondary" exits being manned by able bodied passengers?
I realize that every emergency is unique, and the need to change "primary" and "secondary" exits will depend on the nature of the emergency, but as a guide (so to speak) what do you use? Maybe it would help the question if the situation involved some sort of smoke in the cabin, aircraft has stopped and you need to evacuate the 50 passengers, your primary and secondary exits are which?
One last question, does either the CRJ or the ERJ have slides at their service door?
