flyingfool
- Jun 4, 2005
Does anyone have a copy of the CRJ circuit breaker reset guide that they can PM me.
Aftermath
The NTSB probable cause statement is as follows: "The National Transportation Safety Board determines that the probable cause of the accident was the flightcrew's failure to use the taxi checklist to ensure the flaps and slats were extended for takeoff. Contributing to the accident was the absence of electrical power to the airplane takeoff warning system which thus did not warn the flightcrew that the airplane was not configured properly for takeoff. The reason for the absence of electrical power could not be determined."
The cockpit voice recorder (CVR) provided the evidence regarding the flightcrew omission of the taxi checklist. The stall warning was annunciated. Using the CVR the investigators determined that the aural takeoff warning was not annunciated. There was an electrical failure due to a circuit breaker being tripped, but post accident testing did not reveal a malfunction of the circuit breaker.
1-800-maintenance controlDoes anyone have a copy of the CRJ circuit breaker reset guide that they can PM me.
Screw that. Reset the damn circut breaker. If a fire starts, declare an emergency and presto you are a Hero.
I used to think it was a good idea. Then a good friend of mine got into serious trouble when a thrust reverser came out in the air because of this kind of "system re-set" CB pulling took place.
Never pull a circuit breaker without a write up and the specific (and recorded) instructions from a qualified mechanic. They pay you to fly planes, not fix them, and the FAA isn't going to give you a pass because you wanted to be on-time.
My .02.
I just wanted to look at a copy of it. You're all DORKS!!!
FF
Thanks everyone for the little talk on not pulling breakers. That was some good stuff. You all need to chill out. Who said I was going to use it. I just wanted to look at a copy of it. You're all DORKS!!! Thank god I never have to fly with any of you.
FF
So thats how it happened. Was that the one shortly after the rotor burst out of DEN?
Good, You are an F/O and are not to touch ANYTHING! You can look at anything, just don't touch anything. BTW, "just wanted to look at it", PM it to me, you really are a fool if you think anyone is believing that line of krap!Thanks everyone for the little talk on not pulling breakers. That was some good stuff. You all need to chill out. Who said I was going to use it. I just wanted to look at a copy of it. You're all DORKS!!! Thank god I never have to fly with any of you.
FF
