dpilot_citation
- Dec 3, 2003
We are currently overhauling our TIO-540-SAID. And through out this process we have been trying to repair heat damaged areas. IE: Firewall, Engine Mount and Turbo brackets. All of the coatings I have looked into are good to about 400 degrees, but the areas around the exhaust and the turbo obviously gets much hotter.
Has anyone ever used ceramic coatings say on the engine mount? I talked to our local FSDO guy and he said they leave coatings up to the local A& P. But that he saw no problems as long as the coatings didn’t change the weight or the size, of the mount. These ceramic coatings are good to 1600 – 2000 degree range depending on who you talk to. Some have been tested to over 2400 degrees.
This seems like a good solution to an ongoing problem of heat damaged engine mounts on high horsepower aircraft. I have been trying to find a down side but as of yet…none.
They can also coat the exhaust pipe inside and out. This reduces the radiated heat by 50% or more. There are other benefits besides heat reduction, they claim a longer life out of the exhaust system. It reduces the thermal expansion and corrosion giving a much longer life. Some claim 10 times longer.
The only downside I can find to ceramic coating the exhaust is the reparability of the pipes. You would have to bead blast the finish away inside and out. If you where not able to get all the coating off repairs may not be possible because of contamination to the welds.
Has anyone done one or the other? If so what were your results?
I welcome any and all thoughts and comments.
Thanks….Dpilot_Citation
