cargoflyr69
V-Dub for Life
- May 20, 2003
Got an update. i flew a bit of an x/c yesterday morning and lost about 1.5 qts in 2 hours (we went for a diagnostic 100hr hamburger) Before doing that i washed EVERYTHING on that airplane and when we got back we pulled the cowl and went over everything with a fine tooth comb. it does look like there is some fresh oil coming off the breather and burnt oil in the exhaust stream, on the belly and strut only on the #1 cylinder stack. we did another compression check and got 76 at TDC and 70ish and hissing at TBC. We cant tell where the air is going (valves, breather, oilpan, fill tube, ect. as was previously mentioned) its easy enough to pull the jug, so we did. the rings were all there and intact. There is a good engine shop in town that will be able to check all the jug/piston components for under 50 bucks and tell us what is up. Thats the route we are going to take for now, unless anyone has other ideas.
On a positive note I did get to fly yesterday and have green beer afterwards!
