cargoflyr69
V-Dub for Life
- May 20, 2003
I have a C-90 that is attached to an Aeronca Champ. In the last 15 hours or so the oil consumption has shot up significantly. it is around a quart every 4-5 hours. previously it only sipped oil maybe a quart per 20-25 hours.
I changed the oil myself and within 3 hours it had gone to from honey fresh color to chocolate syrup color. not good i think. I had a compression check done and all 4 are in the mid 70's except that on #1 you can hear air escaping past the rings at the bottom of the compression stroke. the other 3 dont do this.
My mechanic thinks that my oil problems have to do with a bad crankcase prop seal, and a bad #1 cylinder. he wants to replace both. he says the good news is I can get a new cylinder assembly for around $650
My question is how the prop seal has anything to do with the problem, and if the whole clyinder is really bad and not just needing new rings. I've only owned the plane for 200 hours, but the engine was toppped 600 hours ago and that cylinder was replaced then. so, i should think it should be fine at 600 hours and maybe just needing a ring job vs. all new hardware. Am I wrong?
thanks for any constructive thoughts or discussion! I want to get my motor running right for the most value of my dollar and i dont want to have to throw more money at it in another 200 hours.
