supsup
waiting
- Jun 22, 2002
It seems like weekly you hear of incidents or fender benders at the airlines. I was just curious what happens to the crew of these aircraft? How do the companies and unions handle these situations. Here is an example.
http://www.ntsb.gov/ntsb/brief.asp?ev_id=20040121X00083&key=1
Scheduled 14 CFR Part 121: Air Carrier operation of SKYWEST AIRLINES INC (D.B.A. Skywest Airlines)
Incident occurred Sunday, January 18, 2004 in Rapid City, SD
Aircraft: Bombardier CL-600-2B19, registration: N595SW
Injuries: 35 Uninjured.
This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed.
On January 17, 2004, at about 2209 mountain standard time, a Bombardier CL-600-2B19, operated by Skywest Airlines, as flight 3855, contacted the runway with the left wing tip, while landing on runway 32 (8,701 feet by 150 feet, dry concrete) at the Rapid City Regional Airport (RAP), Rapid City, South Dakota. The airplane received minor damage to the wing tip. The captain, copilot, flight attendant, and 32 passengers were not injured. The 14 CFR Part 121 scheduled passenger flight was operating in instrument meteorological conditions on an instrument flight rules (IFR) flight plan. The flight originated from Salt Lake City, Utah, at 2035.
The crew had flown the ILS runway 32 approach into RAP just prior to the incident. The air traffic control tower at RAP was closed a the time of landing. Flight 3855 was in contact with Ellsworth Air Force Base approach control.
A special flight permit which was completed after the incident states, "Crew said when they landed they were heavy with ice, and got no flare on landing. Landed pretty hard capt said and had contact on runway with lt wing tip."
Inspection of the airplane on the following afternoon, revealed 1/2 inch to 3/4 inch of rime ice was visible on the tail, windshield wipers, and unprotected areas of the airframe.
The RAP weather observation were recorded as:
Observation Time: 2211 mst
Wind: 070 degrees at 6 knots
Visibility: 1/4 statute miles with freezing fog
Sky Condition: Indefinate 100 feet
Temperature: -2 degrees Celsius
Dew Point: -2 degrees Celsius
Pressure: 30.13 inches of mercury
What will likely happen to this crew? Any thoughts?
supsup
supsup
