When did the Air Force change the regulation reguarding Color Vision?
I know before the reg change that, if you failed the PIP (Plate test) you would then take the Night Vision test (FALANT, I believe). But since the reg change, if you fail the PIP test initially, you're done, no UPT for you.
Secondly, has anyone ever found out about any waivers that were given for color vision.
