Ran into a problem with #1 xponder on this unit. Hit the test button and it listed dIAG code #23. Problem is, the manual for the unit only lists 1-10 and neither 2 or 3 made any sense.
Anyone with a maintenance manual of some kind shed some light on this code?
The reply is in and the answer is..........no such code. There is probably an issue with the CAD-62 or the CTL. If you have a dual installation you may be able to swap them around to find the culprit.
