FoxHunter
- Jan 4, 2002
When the temperature at a reporting airport is cold altimeters always read higher than the true altitude. The accepted correction is 4% per 10 deg below ISA. If the reporting is -25C it is ISA-40 which yields a 16% error.
In this case if you set the ILS Mins to the published 200' HAT you would actually be 168' HAT when your altimeter read 200'. If you were flying a VOR approach with MDA of 500' HAT you would actually be 420' HAT when your altimeter read 500'. Circle at 1000' HAT, your actual altitude is actually 840'.
Legal, not legal to not make the correction for the cold wx altimeter error???????
