Basically, the airplane goes fast enough that the airflow over the wings is no long "attached" to the wing. All lift is lost, the nose points down and like Falcon Capt. said, you're history. The only way to get out of it is to slow the airplane down, if you can. To avoid it, don't go over the critical Mach number for the airplane you're flying.
That sounds familiar... was it they pulled the slat cb and extended flaps a little? when the cb was reset, the slats deployed and were torn off?tothelineplz said:The S/O pushed in the CB's after he got back to the deck without consulting with his boss who was demonstrating something to his FO.
Sure... no problem!tothelineplz said:By the way Thanks To all readers:
Please change the context of my posts. Thanks agani!
