Class D airspace question.
BushwickBill
Registered Abuser
Quick question on class D airspace. Is there a set distance? Or is it up to the individual airport?
Yes I ran a search. The first result was "will pilots be replaced by UAV's?" I don't get on with flightinfos' search engine.
Here is the situation. On a visual into an busy airport without an approach control I checked in a 4.5 miles. The radio was out of control busy. 6 aircraft in the pattern, loads of them don't speak english very well. Corporate mixing with training aircraft. Nightmare. Captain says I checked in inside of airspace. I always thought class d was 4 miles but I can't find a set distance in the FAR. Checked 91.129.
Thanks for your time...
You may have been inside the Class D whne you contacted the tower, or you may not have been. Generally, and I use the term loosely, the diameter is 4 miles, but there may be extensions for IFR approaches. This is from the AIM:
3-2-5. Class D Airspace
a. Definition. Generally, that airspace from the surface to 2,500 feet above the airport elevation (charted in MSL) surrounding those airports that have an operational control tower. The configuration of each Class D airspace area is individually tailored and when instrument procedures are published, the airspace will normally be designed to contain the procedures.
b. Operating Rules and Pilot/Equipment Requirements:
1. Pilot Certification. No specific certification required.
2. Equipment. Unless otherwise authorized by ATC, an operable two-way radio is required.
3. Arrival or Through Flight Entry Requirements. Two-way radio communication must be established with the ATC facility providing ATC services prior to entry and thereafter maintain those communications while in the Class D airspace. Pilots of arriving aircraft should contact the control tower on the publicized frequency and give their position, altitude, destination, and any request(s). Radio contact should be initiated far enough from the Class D airspace boundary to preclude entering the Class D airspace before two-way radio communications are established.
5. Aircraft Speed. Unless otherwise authorized or required by ATC, no person may operate an aircraft at or below 2,500 feet above the surface within 4 nautical miles of the primary airport of a Class D airspace area at an indicated airspeed of more than 200 knots (230 mph).
c. Class D airspace areas are depicted on Sectional and Terminal charts with blue segmented lines, and on IFR En Route Lows with a boxed [D].
d. Arrival extensions for instrument approach procedures may be Class D or Class E airspace. As a general rule, if all extensions are 2 miles or less, they remain part of the Class D surface area. However, if any one extension is greater than 2 miles, then all extensions become Class E.
ERJ mech. got to it first, so I'll edit my response:
So, in answer to your question, it depends on the airport. They can designate further out, but my experience is that if they are extending controlled airspace for an approach, they usually designate it class E.
I'm gonna be a smart ass, so take this with tongue-in-cheek. You could always look at the chart for the airport you are going into to. Even the Jepp L charts show the Class D shape and size.
If you were 4.5 s.m away, you probably called in the airspace. If 4.5 nautical, you were probably outside. Ring is typically 4.4 nautical miles or 5 statute miles from the center.
Mr. I.
A little ancient history here.
Before all the airspace was reclassified to make our fellow ICAO members happy, I suppose, airspace around airports with control towers were called Control Zones with lateral dimensions of 5 statute miles(plus IAP extensions) and vertical dimension of surface to, but not including, 2500' AFL. People complained for years about the use of statute miles for distances when everbody used nautical miles for navigation. DME distances were expressed in NM instead of SM.
I guess when they reclassified the airspace they changed the regulation to read 4 NM instead of 5 SM so the distance never really changed but the wording did. Apparently they decided to ignore the fact the visibilities and cloud clearances were still expressed in SM instead of NM. Go figure.
Not to be a Smart -Ass but I believe the AIM States "General" dimensions, but ends the statement with "or as depicted". This means what you see on the chart or map. I have seen class D be only 2-3 miles in certain portions. If you look at a sectional you can probably find other airports which dont meet the criteria (NY sectional) good luck.
On the flipside of what Purplehaze said, some Class D airspace is much larger than the typical. One example is BMI (bloomington, IL). My guess is that there isn't enough traffic to deem it a Class C, but the type of traffic and the airports around BMI facilitate the need for a much bigger Class D. Just eyeballing it, it looks about 6-7 miles in diameter.
Hi,
Class "D" airspace is determined by a simple formula. This formula is located in FAA Order 7400.2F. The dimension is determined by measuring the distance from the ARP,(Airport Reference Point), to the end of the furthest runway then dividing that distance by 6076. Then by adding 3.5, this will give you the radius for that specific airport. Hope this helps.
Regards
Does this answer give the distance in NM or SM?
Hi,
Regards
(5000/6076)+3.5=4.3229
I would have looked at the guy like he was crazy. Since you were IFR you've allready been cleared in.
What did he want you to just step on everyone else's calls, and mess things up even more?
You should have told him, that as the PF and the more experienced captain he should have slowed down.:D
Well, it doesn't specifically indicate the unit of measurement, but I believe since the divisor of 6076 is being used it would be considered NM.
Regards
I'm sure the term you meant to use was radius versus diameter. I just thought I would clarify your 4 mile thing.
On a related note, I had a guy look at me like I was crazy 'cuz I pitched up over 12 degrees the other day, no pax, to keep the IAS below 200 kts. He was like, "what are you doing?" He had no idea there was a speed limit below 2500' and within 4 miles of the airport on departure. We were empty, so I guess we accelerated better than usual.
PJ
A little corrected ancient history:
Before the airspeace redesignation, what we now call Class D airspace was known as the "Airport Traffic Area", not a control zone (a Control Zone has become Class E airspace). While the standard ATA was a 5 SM radius, it was 3000ft AGL, not the 2500 that it is now.
Despite the history, any attempt to define a "standard" class D segment are futile. There are plenty of exceptions. For example: I keep a plane based at a tower controlled airport in which the boundaries of Class D airspace are a North-south street, an East-West street, a shoreline, a line between the mouth of a creek and a point of land, and another line between the mouth of the same creek and a highway intersection. The point being, if there are exceptions to the standard, you can't rely on a "standard" definition of Class D airspace, so discussions of "standard" dimensions are merely of academeic interest. The only relevant question is what are the boundaries of the Class D airspace at the airport in question?
No, strictly speaking, you haven't complied with the requirements of 91.129. Remember, he said there was no approach control, so, I'm assuming the clearence for the visual came from Center. 91.129 requires you to "establish communication with the facility providing air traffic services prior to entering that airspace" In this case "the facility providing air traffic services" would be the tower.
Just thought I'd add this experience:
A few days after I made the above post, I took one of my students up to the tower at our airport. Order 7400.9P says the airspace here is 4.0 nm. When I asked the tower manager how big the airspace is, he told me 4.3 nm. I asked where he got that number, and he pulled out his SOPs and showed me the document he has outlining the airspace, which is several years old. Sure enough, it said 4.3 nm. Obviously, one of these documents is wrong. I suspect the SOPs would hold up in court if it came down to it, but who knows. I'd imagine there are tons of other airports with the same circumstances.
Moral of the story: the FAA makes policy, not sense.
Also, I learned something else: our tower is responsible for runway separation, nothing more. Technically, traffic advisories and sequencing are additional services provided on an as-available basis. Of course, in practice, this seems to be their primary job. It was just a bit of an eye-opener for me.
~Mike, a perpetual student of aviation
That makes the trip into APC even more frightening. We are missing an approach sector in the North Bay and center just sort of turns you loose about ~ 10 -15 miles. It's a very crowded sector lots of VFR traffic some without transponders. JAL has training in the pattern and the radio calls can be well quite long. Sometimes 2 or three calls for 1 aircraft. If Tower is not being responsible for seperation then who is? I guess no one? Not a diss on the tower guys I like them all. Maybe more controllers is an answer?
Thanks for all the positive input by the way I have been following this tread for a while.
If tower is not being responsible for separation then who is?
YOU ARE! Visual approach...see and avoid...see and be seen...
Sometimes we need to be reminded.
