CitationShares domiciles
There are a bunch of them, and the CS website has them all listed for your perusal. The website also states that you must live with 120 minutes of your domicile.
BOS, HPN, EWR, BWI, ATL, MCO, FLL, MIA, ORD, DFW, DEN, LAX, SFO, PHX, CVG, SAT, STL, BNA, MCI, IAD, SMF, LAS, IAH, CLE, GSO
CitationShares pilots must reside within 120 minutes of their Pilot Base.
I believe they MapQuest your address from the airport to see if it's within the 120 minute circle.
If you select a certain domicile, are you more likely to get one aircraft type vs. another? For example, if CJ1 shares are more popular on the East Coast and yet you select a West Coast domicile, would your chance of getting assigned the CJ1 be less?
By the way, I saw one of your CJ3s recently - a very nice looking aircraft. Any feedback from the guys who fly the CJ3?
I don't think your base has anything to do with what aircraft you are assigned to. The way I understand it, whatever aircraft needs filling at the time is what you get.
Guys that I've talked to love the CJ-3. The avionics are quite impressive on it. Performance is also good....they say it climbs similar to an XLS and cruises around .73.
Whiskey Tango said:
After you are hired can you change domiciles
You can request for a base change and as long as your new residence is within 120 minutes of the domicile, it will be approved. The basing is only for airline purposes.
who says it will be approved? check your source before you jump.
People change their bases all the time. I based it on conversations with those who have and those who plan to. Is that a good enough source?
