citation X fuel burn
1600
1400
1200
Diesel, I respect your opinion but you seem to be real conservative on your PPH #s.
We usually figure 2500 first hr and then 2000 lbs/ hr. as a general rule above FL400. You can see around 1800 pph at or above 43, though.
There is nothing like being at FL450, sipping 1800 PPH, and doing .88+.
I'd have to agree with SCT. Diesel's numbers seem waaaay too low. Using about 13,000# max fuel, 1600# reserve and his fuel flows would give you a 9 hr range airplane. Which it ain't.
yeah sorry i was thinking ultra when i posted.
try
2000
1800
1600
2500 first hour and then 2000 for each hour after. During the first hour you actually see a burn of about 2200-2300, but using 2500-2000 always works well.
Yeah the 2500-2000 works well too. Usually fltplan.com has a good fuel computation that is pretty close.
The burns i posted were at .82 which is what i've been doing lately.
Sorry for my messed up info. :)
I have flown the X for several years now, and never cruised at anything but max cruise. The exceptions are while in the tracks, or when you really need long range cruise performance.
I am just curious why you would fly at .82? Is it to extend the range?
Yeah doing a lot of long haul legs. Or full of pax going from bos to san during the winter. Probably out of a tour for brand X i end up doing 3 or 4 legs at .82.
You know how it is rather go non stop at slow than fullspeed and stop.
According to the manual Mach 0.82 is Longe Range Cruise and will give you a range of 3,098 nm at ISA with 4 pax and NBAA IFR Reserves.
GV
Yeah, I know that .82 is LRC. I just have never had to use it hardly at all. If I am traveling from east to west in the winter and battling strong headwinds I usually step climb later in the flight to save fuel.
152 i'm behind you i like to climb instead of going slow. I've had a couple of trips where I've had to climb and also do .82 Sad. Usually though I like to climb the fuel flow and let the speed settle where it wants to up high.
I know a guy that flies it from south america to miami quite a bit. Starts off at .82 climbst to 470 and then steps it up to 510. I think he was doing somewhere near 8hrs.
