I have seen the II go anywhere from as low as $1450 per hour up to $1900 per hour depending on the region where the aircraft is based. My suggestion would be to contact the 2 or 3 closest 135 operators in your area that have a II on certificate and see what they are getting per flight hour as well as the crew costs, etc. From this research you should be able to get a good idea and be "competitive" with the other operators. This is probably the best way to "validate" your final decision, I surely wouldn't do it based on the responses that you obtain from this thread.
we used to charter ours for $1800 per flight hour and charged no wait time. That was right up to the point that they sold it due to low demand/rate. So take this post for what its worth i guess.
