Citation 560/Pilatus PC-12 job info?
Ultraman
H.N.F. 1924-2003
Does anyone have any additional information on the Citation 560/Pilatus PC-12 job posted on Climbto350? Ad says the job is in Georgia, but isn't specific.
Thanks,
Ultraman
Research tips
Here are some suggestions to identify this employer. Go the the FAA aircraft registration site http://registry.faa.gov/aircraftinquiry/ and search for PC-12's registered in Georgia (insert PC-12 in the "Make/Model name"). Then do the same for this model Citation. Compare the lists and identify the company/owner.
Clue: it appears that there are 8 PC-12's registered in Georgia.
Buona fortuna. :)
Check 6,
Thanks for the tip. However, I had already done that search and didn't find a match. Of course, it's possible that one or the other (or both) is not registered in Georgia.
Thanks again for the help.
Ultraman
OK, here is another possibility, though may be very time consuming. Use flightaware.com to see if there are any commonalities between these aircraft that are registered in Georgia, i.e. if any of these two model aircraft tend to fly in/out of a common airport.
This should keep you busy for awhile. :)
could be CB&T in Columbus, they have a 500 series citation and a PC-12 on the FAA website.
