Check your V1/Vr/V2 calculations carefully!!
Because obesity has become a national epidemic, the average passenger weight should be raised significantly.
It already was. 20+lbs after the B1900 crash. (even though weight had little to do with that one- but got to pin it on weight since the real cause would paint republican outsourcing in a bad light)
The sad thing is though, should you make a mistake on your calculations and t/o 1 pound over your max allowable weight on paper, the Feds will violate and rape you. Because they only care about paperwork. They are not interested in the "real" deal. I bet most full planes take off with a significantly higher pax payload (10-15%) of the max allowable.
True Dat-
Especially if Gen Lee's mom happens to be in the back-swilling cheap ripple, as she usually does.
Obama's a better man than me.
I don't appreciate all the outsourcing- but maybe you haven't connected the dots and seen how outsourcing has affected you personally? Do you not see how it has helped shrink the middle class and widen the gap between the rich and poor?
