CFI renewal and the 8710
Northern Lights
Just finished the Gleim FIRC.
When filling out the 8710, is it necessary to flill out the "Record of Pilot Time" section, seeing as I already have all of my certificates? I always have in the past, but I'm not sure if it is required.
Also, do I need to fill out section 2, "Certificate or Rating Applied for on a Basis of:"
I would put "Graduate of an approved Course," but again, I already have the certificate, not applying for something new.
I did Gleim 2 years ago, but I can't quite remember what I filled out.
Thanks in advance.
1. You do not need to fill out the flight time section for a renewal of a CFI. However, like Patmack said it is a good idea if you ever lose your logbook, your last 8710 can be legally used to start your logbook with. If you want the reference I'll look it up. I posted it on this forum a couple of months ago.
2. You do not fill out Section two because you are not applying for a new rating. If you have any questions you can ask at the FSDO you go to when you re-new.
JAFI
