Felony
Dear Troy,
Don't worry about it for your CFI job. I wouldn't say a thing, unless you are required to get a SIDA badge.
When you get ready for Part 121 or whatever, TSR 1542 only calls for a 10 year background check. So that means if you need a SIDA badge for your position and your felony has been in the past 10 years you are out of luck. After 10 years, you are good to go. There are 27 felonys you can't have on your record and get a SIDA (security identification dispay area) badge in the past 10 years. After 10 years, the FAA, TSA, doesn't seem to care. Hope this helps.
WK
