CFI done and dusted.
IrishFlyer
Wacky and Waving
Hi Guys,
Just wanted to let you know I passed my CFI initial yesterday. I did the oral last Thursday over at the SAT FSDO, then got a message that the aircraft we would be using had gone tech. So I got a letter of discontinuance and rescheduled for yesterday. I waited most of the day for clouds and CBs to clear then took the test. Straight forward oral, four hours no curve balls and likewise for the flight - 1.9 hours.
Thanks for all your help and information posted by you other CFIs about your check rides on these boards.
Off to get a job....
IF
Okay.
We basically hit on most topics in the PTS, some in more detail than others.
Ground: Four Hours
FOIs:
Human behaviors and effective communication
Critique and Evaluation
Flight Instructor Characteristics and responsibilities
Planning Instructional Activity
Technical Subject Areas:
Aero medical factors - Scenario based questions. Carbon monoxide poisoning
Visual scanning and collision avoidance - Went into more detail during the flight
Principles of flight - Very thorough. Know in detail. Especially the left turning tendencies and ways to counteract them.
Weight and Balance - A quick overview of why, how, different ways of doing it and definitions.
Navigation and flight planning - Opened up the sectional and asked questions about airspace, VFR cloud clearance and visibility requirements, a lot of what if questions and how would you plan A to B.
Logbook entries and certificates endorsements - Very thorough with this. Many scenario based questions. When do you need a high altitude endorsement, can I train a candidate for ATP.
Certificates and Documents - Who can issue a student pilot certificate and medical. How long are all three medicals valid for. Can you give flight training to an amputee. What training you need to give to a Private and Commercial candidate. Can you give training for an instrument rating if no CFII.
Operation of Systems (PA28R-200) - Gear, Prop, fuel injection, engine, Pitot static, vacuum, instruments.
Performance and Limitations - Tied in with weight and balance. Air density and its effects. Airplane limitations.
Airworthiness Requirements: Done during the preflight. Documents needed. Instruments required.
Preflight:
Asked what nearly every vent and aerial was for.
Location of battery. What sort of battery.
Asked what something was inside the engine. At first I though it was the magnetos casing but I figured it out to be the oil pump for the prop.
Gear - Switches
Alternator drive belt questions.
Continued with regular preflight.
Flight: 2 Hours
Airborne:
Normal takeoff
Steep Turns - I did one then he did one and I critiqued.
Stalls - Power on, Power off
Chandelles - I did one then he did one and I critiqued.
Lazy eights
Emergency approach and landing - Cut the power and said we have a failed engine.
Eight on pylons
Uncontrolled airfield procedures
Soft field landing
Soft field takeoff
Short field landing
Short field takeoff
180 Power off approach and landing
Touch and go
Retuned to SAT
He flew and told me to put on the hood. Then he transfered control and he gave me vectors and decent instructions right until short final when he advised me I could look up.
He focused a lot on the transfer of controls.
Altogether a very fair and through test. The flight portion was not as long as I thought it would be.
Regards,
IF
congratulations!! hopefully within the next 1.5-2 years, i will be passing the same test!
Congrats, dude! A word of advice to ALL the CFI's out there....don't EVER let your CFI expire. It's VERY easy to renew it even after you quit instructing - just a 16 hour refresher course(less if you do it via the online renewals) once every two years. I had mine renewed a couple times based on the number of checkrides I had sent students for, but then I've done it four more times via the refresher courses. I know quite a few guys that let their CFI expire, and really regret it.
I've reinstated mine twice after letting it expire...not a big deal, but it's a whole lot easier just to renew before hand and be done with it.
Re-instating requires a checkride, doesn't it? Renewing requires as little as a CFI refresher course...or you could do a checkride, if so desired.
