Central MD/Northern PA/Northern VA/Eastern WV cargo bases
ceo_of_the_sofa
Registered User
Are there any piston cargo 135 outfits with bases in Central or Southern MD/Northern PA/Southern VA/Eastern WV? Basically, anyone within a two hour's drive from Baltimore?
Ram Air Freight does...there's a base in both BWI and Martin State. There's also a base in Richmond but that's about a 2.5 hr drive from Baltimore.
-W
How senior are the Maryland bases? What about Richmond? Can you bid right after training?
Dennis
Actually, Ram has recently pulled the MTN base. The BWI base goes VERY junior. It is the worst run in the company.
OFP, (near Richmond, VA) is our second biggest pilot base. There are five pilots based there, and its pretty easy to get there if you want it.
Bids after training are based on wherever open runs are.
PM if you need more info.
