CE-208/single engine W&B
cdog
What information needs to be included on a load sheet / manifest to satisfy FAR 135 W&B requirments (single engine acft)?
You're probably thinking of the manifest required under 14 CFR 135.61(c). This only applies to multi engine airplanes, however.
You are still bound by 91.103, which requires that prior to beginning a flight, the PIC shall become familiar with all information regarding that flight.
You are not required to have a completed weight and balance form on board. However, it's a good idea to be able to show how you determined your airplane, as loaded, is in compliance. Accordingly, you may keep a calculation showing the same load, if you use it regularly, or you may calculate it every time.
I know an individual who was ramped while flying a single engine airpane. The inspector demanded a completed weight and balance for the load. The individual excused himself for a trip to the restroom, and returned several minutes later with the weight and balance written on a length of toilet paper. He instructed the inspector to flush it when he was done, and departed with passengers and cargo. I don't recommend this, but it worked.
