GoABX said:Cat IIs can either be coupled or hand flown (driver's choice). ABX is the only carrier authorized to hand fly engine out Cat IIs. 76's are Cat III and system should be turned on in ILN shortly. Obviously, Cat IIs are cool. This winter we'll see if the extra 100' makes a difference between Astar and ABX; if it does maybe DHL will upgrade you.
Since he said you can't deautomate, that must only mean an autoland, DUH!LJ-ABX said:Ah, so Cat II must all be autoland then?
