Can turbulence fear be overcome with more flying?
RUNNINHORN
Hook em Horns!
I absolutely love to fly, its something I day dream about all day, and love it when I finally get up there. But ive got one fear that I formed when I first started training in a 152 last year with my old instructor. He tried to "scare" me my 2nd time up. He basically tried to show off one day when we had some serious turbulence, lost control for a few secs, then he regained control. Basically scared the hell out of me, and ever since, I get the jitters when we hit some significant turbulence in these small planes.
Do you think that can be overcome the more I fly? Or is that something that cant be overcome?
Of course you will get over it the more you fly. There is always a chance that something could happen up there, but the more you fly the more you realize that the likely-hood of something significant happening is not going to come from turbulance. After a while, it becomes fun until you get into IMC and actually have to work. Then it just sucks.
Keep flying you'll get over it. Sounds like a real idiot you had for an instructor. Don't ever settle for a stupid flight instructor.
Also, a strong education of understanding the reasons why turbulence happens, and when it happens, can also help ease fears.
In one word...YES! Stick with it. TX sucks, but eventually you'll get use to it. You might not even notice the light stuff anymore, and moderate may just become annoying to you. Stay away from the severe! There's no cure for that in a GA airplane.
Yep, I'd have to agree too.
Just remember to slow to Va and maybe even a few knots slower. It's kind of like a washboard road, the faster you drive over it, the worse it gets. The slower you go, the smoother the ride. I know it's hard to believe and when you're in turbulence you just want to get through it quickly, but slow down and it becomes less violent.
EDIT: Resocha and I were posting at the same time, but an understanding of turbulence makes a world of difference.
Keep on flying...
eP.
if you dont mind me asking, why does it happen? I flew back on Southwest last night, taking off we had some serious turbulence out of dallas, felt like the plane was moving sideways, plane was all over the place as we were climbing......
I used to be a little freaked out by turbulence and I would hold the panel with my right hand to steady myself when I hit the bumps. Now after some more experience dealing with moderate to worse turbulence and such I can just sit there, cross my arms and ride em out with no worries. The more you fly the less you worry about it and eventually it can be fun, if it isn't beating the hell outta ya.
RUNNINHORN said:
Iwhen I first started training in a 152 last year with my old instructor. He tried to "scare" me my 2nd time up. He basically tried to show off one day when we had some serious turbulence, lost control for a few secs, then he regained control. Basically scared the hell out of me, and ever since, I get the jitters when we hit some significant turbulence in these small planes.
First off, FIND A NEW CFI!!!!
Any CFI who tries to show off and "scare" a student isn't worth a dime. If you are scared you can not learn anything. Nor should you ever tolerate a CFI yelling at you, it's not acceptable.
Find a new CFI who will be patient with you and allow you to relax in the plane. Turbulence is a fact of life, you just have to learn to "go with the flow". Once you learn to smoothly controll the plane you will get much more comfortable. This is a perfectly normal concern. Flying in Texas summers I have seen more than my share of turbulance, it makes every student nervous for the first few flights.
To learn about the most common cause of turbulence in a Tx summer, go boil a pot of water on the stove. Watch how areas start to produce a line of bubbles on the bottom of the pot, bubbles which rise rapidly to the surface.
That is a lot like the atmosphere next to the sun-heated Texas hardpan in August. Boil boil boil, anywhere below 10,000' you are gonna get a butt-kicking.
Now the cause you experienced in the SW airplane might have been the recent passage of some weak cold fronts they have experienced. And there are other reasons for turbulence.
I used to puke in light airplanes when I was learning. I know an F15 pilot who used to puke into his shirt and lie about it in order to continue his training and not get disqualified. We both got over it with a lot of hours, especially hours in the left seat, with cold air blowing on us. So fear not, you can overcome this!
Turbulence is simply caused by air masses moving in relatively different directions or different speeds. Imagine moving along in a "current" of air and encountering another "current" moving at a 90 degree angle from below. The boiling water example above is a good example. Also, have you ever been on a very fast boat? When the water is smooth, the boat just zooms along, but when the water is choppy, the ride is very rough. It's nearly the same for airplanes, but you often can't see the bumps coming.
Though turbulence is a simple concept to understand, its causes can require a doctoral dissertation, and includes everything from thunderstorms to wake behind larger aircraft.
Keep on flying, my friend. Turbulence is just bumps in the highway.
Yep.
With knowledge of what it is (as has been explained very well here), time and experience in it, you'll get over your fear.
Several years ago, I got CO poisoning (from a cracked manifold) while in IMC and somehow made it to my destination. It was the longest 45 min. of my life.
For well over 2 years after that, I'd still have mild panic attacks almost everytime I flew, especially when I went over 12,000', which is common around here. I'd put a hose up my nose before ever turning the prop on the ground, but that didn't really stop it.
I kept it well hidden, but I could feel my heart racing in my chest. I almost gave up flying.
Now, the tube up my nose is gone (I fly pressurized now) and I'm complaining when controllers won't let me climb high, or keep me below FL200 for traffic, etc.
It just takes time/experience.
Yep. I almost quit because of it. I was more afraid of not making it in aviation that I was of turbulence.
Lose the instructor. Better yet, someone needs to give him a blanket party in the parking lot!
I was told that turbulence is just like pot holes in the road or burbles in a stream. The problem with that analogy is that you can see the burbles or pot holes. Turbulence just sneaks up on you.
I came to realize that, unless you fly through a level 5 thunderstorm, planes just don't get ripped apart in turbulence. It'll take some time but you will get over it and go on in your career. Good luck.TC
You may find it very uncomfortable now but later on it will be just plain ass annoying while you try and finish the crossword at cruise.
Turbulence can be caused by all kinds of things. You can sum it up into cliff notes of about 4 main causes. The first main cause would be the wind and how it reacts with other stuff around it (IE wind blowing in different directions and speeds this is usually found near fronts. Or the wind reacting with the ground. If wind hits a building or hill or something like that then the path of the wind chagnes and you can get waves and burbles and stuff like that. This usually happens in the first few thousand feet above the ground and my guess is thats what happend on your SW flight) The 2nd main cause would be thunderstorms (lots of air moving in all kinds of directions so thats just a whole bunch of nastyness). The 3rd main cause would be wake turbulence (planes moving through the air stir up the air behind it cause burlbes and turbulence). The last main reason is Thermals (this is usually in the summer time and the boiling water is a great example. Usually only get this in the first 5 or so thousand feet or so. But on really hot days with lots of thermal activity you can get it even higher). Turbulence is basically caused by the movement of the air around your plane. There are just a few things that can cause the air movement around the plane to cause bumps. Hope that helps
how about the jet stream? crossing it where shears are great can cause the greatest turbulence..aside from T-storm penetration! (dont go there)
I freakin' hate TX. That said, I've been through so much when I was a freightdawg and working in the fire environment it's become more of a nuisance now.
So...yeah...like everyone says, stick with it. You'll learn to understand where/when it happens and, sometimes, you can avoid it. When you can't, you'll find out just how far you can cinch down your seatbelt and shoulder harness!
Oh yeah...I'll ditto the new instructor deal. Don't need someone scaring newbies out of the business/industry!
Eric
You'll get past it
When I first learned to fly I used to get sick all the time if there were bumps or it was hot. Finally after trying what seemed like every other alternative.... patience, education, flying on less windy days etc My instructor just sat me down and said "Look, you're in a little plane, it bounces around, its going to be hot, this is how this is supposed to work. You're going to have to get past this in order to continue flying." That common sense jar was all it took for me, if that doesn't help you, just stick with it and eventually you'll get used to the bumps. Try to picture the plane your flying from the outside and what it looks like bumping around a lot, its normal for little planes to do that all the time. Like someone said earlier, all they do to me now is disturb my crossword puzzles.
Oh yeah, and don't ever put up with someone you are paying yelling at you. If you're a motivated student and all you want is to learn to fly you deserve much better than that.
It's the fear of the unknown. You're just not comfortable with it....It happened to me when I was first introduced to stalls. Keep flying if you love it though. Just remember: Turbulence is like bumps in the road in a car....or something along those lines....
