glasspilot
- May 17, 2004
It was 2005 and I was pretty upfront about my reference. It wasn't my average weight program. I didn't write the rules. The FAA approved the program. Under it, gate-checked carry ons (the ones in the back cargo) weighed 10 lbs. If they were not gate-checked and instead came on board with the pax then the weight was considered to be part of the pax average weight.
If that has changed then I'd like to know how the rule has changed. Do they add the 10 lbs even if it's in the cabin or do they try to write a rule that says you can't move bags to accommodate a JS? Don't just tell me it's "technically prohibited", instead tell me what's different from the average weight program I just described.
So you would only have to move 9. Makes it easier then. You have to work with the rules, however crazy, you have. It wasn't "technically prohibited" when we did it.
It's a sore spot for me because I was a commuter and saw plenty of guys not doing what they could legally do to help a brother out. Obviously if revenue is being kicked off for whatever reason then the JS is out of luck. But many many times RJ drivers are just saying "no" for no reason.
ACA did, however that was 6 years ago and they're defunct now. At the time a carry on weighed 10 lbs if it was checked in the cargo and zero if it was in the cabin (actually it was simply included in the pax average weight, but that's the same thing as zero really).
So you just move 18 of them into the cabin and you magically have the weight for the JS. Weather you actually move them or not is up to you. Point is there's never (almost) a valid reason to leave a JS behind.
I have had airports as close or closer to ATL just take an estimated wheels time. I understand what you're saying, but does the decision to wait or get an expected wheels up from the crew up to the discretion of the controller? I would think if the crew gave a time and couldn't meet it, that it would be their fault and they'd have to deal with any further delay. That being said, why would a controller care if they don't make the time? He/she isn't the one sitting with the added delay if any, so why not call with what the crew gives as an EWU every time?
The controller in the tower does not usually have discretion as to when to call the TMU for release. That procedure is spelled out by the center in question.
For example, ZJX requests estimated wheels up times from aircraft 30 minutes prior to departure. So, when coming out of MCO or PNS to ATL, you can call ground or clearance, and give them an ETD.
Mobile, which is located in ZHU, obviously has a different procedure dictated by Houston Center, and does not want you calling for release until beginning taxi.
That overweight 1900 in CLT was like a decade ago. Regardless, sinkrate, this was just a stupid side discussion while I was waiting for you to get back on that whole "MZFW to MLW is only a 3K split so I can't launch on a 45 minute flight" thing. Have you conceeded that one or do you still think you have a point in there somewhere?
Trust me, I'd much rather talk about that than some old w&b policy.
I never bumped the JS unless revenue was also being denied.
I'd still like to know when you have ever been up against max landing weight (short flight with small burn) and max take off weight (full of pax and full of fuel). If it's such a short flight to worry about max landing then you shouldn't need that much gas to worry about max takeoff weight unless, as I suggested, your alternate is far far away.
Please give an actual city pair with an actual alternate where this actually happened to spark your "rant". Thank you.
