cargoflyr69
V-Dub for Life
- May 20, 2003
I have a C-90 that has a strange leak coming from the airbox. It seems to be a diluted oil/gas mixture. It pools in the bottom of the airbox and leaks and drips out of the front just below where the air filter bracket screws in. This is the same area you'd see raw gas collect whe you flood the engine too.
Where is the oil and gas mix coming from?
Are there any crankcase seals or gaskets that the airbox passes thru to join up with the carb and induction system?
The engine runs fine although a bit tired. It's oil burn is 1qt/5-6 hours
