deskjobssuck
- Jan 7, 2002
Just one bit of advise...
Get a Hawker with the TR's and..
USE THE THRUST REVERSERS TO THEIR MAX POTENTIAL ON LANDING or RTO! And you should not have to worry about real world Brake Energy Limits on a Hawker.
I've flown everything from 15,000lbs to many hundreds of thousands, and if you use those TR's the way they're intended, you hardly need touch the brakes on most landing until you're about to take the high speed..
Short runways, then all bets are off..
Be careful with that school of thought. Though I agree with you, there are LOTS of people on here who believe you are a hack puilot if you are not dogging out the brakes out as soon as the mains touch because you should be concerned about the aircraft on final having to go around. I know, that's laughable, but plenty of folks out here who think that way and have no problem telling you all about it.
Deskjob,
Whenever an aircraft is stopped using the wheel brakes, the kinetic energy stored in the moving aircraft is transmitted to the brakes. The by-product is heat. The faster the aircraft is moving or the heavier the aircraft when the brakes are applied, the more heat is generated in the brake assembly. Once the brake reaches a certain temperature, it can no longer absorb any more energy and therefore brake effectiveness deteriorates to the point of no longer stopping the aircraft. Depending on the aircraft and brake manufacturer and the material used (steel, carbon), the brake energy limits can vary greatly...
Unless, of course, your takeoff weight is above the limit specified in the AFM table for the field elevation and conditions present. Then it's 20 or 25 minutes.Deskjob:
The 800a that I fly requires a 5 minute cool down after taxi in to taxi back out.
