B&CA Legacy Operator Report
LegacyDriver
Moving Target
It figures this issue would get lost in the mail.
Does anyone have a copy of this from the online B&CA site they would be willing to post?
Many thanks.
What I got out of the article is you can get a plane that has large cabin length, with less width and height (even with a dropped floor) than a Gulfstream but more baggage space, for a midsize aircraft price and range. It has the cruise speeds of a Citation (402 KTAS), can't climb that high (41,000 with a mod), has a low max differential pressure (8,000 foot cabin at FL410), and the avionics are severely outdated (unable WAAS or RNP approaches) that will require Embraer to eventually address with a significant update. All of this plus a noisy cabin and cockpit. They never did give any examples of runway performance numbers. What is a "relatively short runway" and how far can you go off of it? It does sound reliable and easy to fix.
Overall it sounds like a great airplane for a charter company that needs to offer the large cabin impression for a low price or a company that needs to move a lot of people around in a shuttle type operation. For long-range international flying that the true large-cabin business jets are designed for, it doesn't seem to compete well.
In operational reality the cruise speed is higher than cited in the article. We used to do coast to coast into the wind at .795M until fuel got really pricey and we never had range issues. As the article correctly notes, the published performance numbers are conservative. The airplane exceeds them by a fair margin.
The mod is ONLY for the first 35 or so built. Everything built from roughly s/n 854 (or 939) on--I forget the exact plane but I did fly it--comes FROM THE FACTORY with FL410 capability.
The airplanes that equate to "Legacy 600" models are light years quieter than the older models due to soundproofing improvements (and the VGs above the cockpit "hump"). The guys complaining about noise in the article own early S/N airplanes that were indeed loud above .76M. EVEN ON THESE, if you close the doors (cockpit,galley, and lav) the thing is MUCH quieter. Most operators fly with the cockpit door open and that makes the older models significantly louder in the cockpit and galley.
The avionics can use some upgrades, but I haven't had any issues with it. I find it hard to believe that a little "reprogramming" couldn't fix these complaints...
Runway length required for a max weight, max range takeoff from sea level at roughly 100 degrees F is just under 6000'.
Absolutely bulletproof. A tank.
If what you do is mostly CONUS, Hawaii, and East Coast to London, or bouncing around Europe or the Mid-East it competes handily. If I'm bouncing all over the world I like to know my jet will absolutely work and that if something's busted I can defer and keep going. That 99.9% reliability thing is for real on this bird.
If one needs more than 3450NM range...and if price isn't an issue and reliability isn't an issue...then one should buy a Global, Falcon, or G-String.
