Avasi:
1. The act of blocking an uppercut in Fredlundvania, in May
2. "A Vasi" pronounced by someone from Brooklyn.
3. A well known and recognized brand of Itallian suit, made only with natural silk fibres, and a trademark line of pastel colors.
4. isavA spelled backward.
5. Avasi stands for abbreviated VASI, also known as VASI-2, or the 2 Box VASI. It is a type of economy approach lighting aid. "Economy approach lighting aids" includes a medium intensity approach lighting system (MALS) that may include a sequence flasher (SF); a runway end identifier lights system (REILS): and an abbreviated visual approach slope indicator (AVASI).
The 2 box VASI, or VASI-2 (AVASI) is the typical VASI you find at most smaller airfields. It's just two transmitting boxes, with a multi-path indication of high, low, and on-glidepath. The abbreviated visual approach sope indicator is the most common kind.
There are three basic configurations of VASI that are described below. These are left side of runway, both sides of runway, and the walker 4 bar configuration. Each configuration has several variations on the theme, and different limitations as follows:
1. Left Side of Runway:
VASI-2 consists of two light boxes. This system provides descent information under daytime conditions to a distance of 3 miles.
SAVASI-2 consists of two light boxes with a single lamp in each box as. This system is designed for nonjet, utility airports, and provides descent information under daytime conditions to a distance of 1.5 miles.
VASI-4 consists of four light boxes installed. This system provides descent information under daytime conditions to a distance of 4 miles.
2. Both Sides of Runway.
VASI-12 consists of 12 light boxes installed. This system provides descent information under daytime conditions to a distance of 5 miles.
VASI-8 consists of eight light boxes installed. This system is basically the 12-box system with the outer four boxes removed and provides descent information under daytime conditions to a distance of 5 miles.
3. Walker 3-Bar System.
Walker 3-Bar VASI-6 is a 3-bar system installed. Each bar consists of two light boxes aligned on the left side of the runway. The system provides descent information under daytime conditions to a distance of 3 miles.
Walker 3-Bar VASI-16 consists of 16 light boxes installed. The system is basically a VASI-12 with the addition of a 2-box light bar on each side of the runway which provides an additional visual glidepath at a higher angle. The lower path is designed for large aircraft. This system provides descent information under daytime conditions to a distance of 5 miles.
