ATP Test Scores - Any way to retrieve?
milflyboy
I can't seem to locate my scores from my ATPL exam and I now need them for an interview. Is it possible to retrieve the results somehow?
You are talking about the written, right? I think there's a way to get another copy of the test certificate from the FAA, you'll pay maybe $20 for it. Call the company you took the test with (CATS, Laser Grade), and they should be able to help you.
You can request from the FAA your airman's records. Included in those records will be every written test score you've ever taken. It's been awhile since I've done it, but it's not a set price. They A(the FAA) recommend you send in x amount of $ for copy fee's and then depending on how big your file is they refund to you what's left.
I thought most employers don't ask for this type of information.....I thought it was pass-fail....not that i would purposely " land just over the mark" I would do my best...But most have said they have never had anyone ask for this when applying to avjobs???? which carrier is it or is it an instructing job?
Well good luck with Cathay.
They fly mostly large aircraft so you might get ok salaries...even as a F/O. Much luck to you.
