assistant chief pilot?
Tug Driver
I can't keep a girlfriend
is there such a thing as an assistant chief pilot? if so, is there a certain time requirement like the regular chief pilot position? or is it just a title?
thanks
nicko
No requirements
No, there is no FAA requirement for any qualifications to an Asst. CP. or Asst. DO, or Director of Training. They might like to see a resume for their info, but it is not addressed in Part 119
asst chief pilot
Actually, there is an hour requirement for asst chief pilot. Look in FAR 141 under chief pilot and asst chief info. That is where you will find the real skinny.
bertengineer
bertengineer
I think he is talking for a FAR Part 135 Charter Operation, not a FAR Part 141 Flight School...
I don't have a FAR in front of me but I thought the Director of Training did have certain requirements.
Nope
Not listed in Part 119, but most Feds want to know who is going in that spot.
The only requirements for 135 are:
1) Dir of Operations
2) Chief Pilot
3) Dir of Maintenance
4) Chief Inspector (if approved for 10 or more passengers operations)
Everything else is just a title (no hour/experience requirements). A Director of Safety is required for 121 ops.
The only required positions for 135 as listed in 119 are:
2) Chief Pilot
Asst.
While it is not a REQUIRED position most FSDOs do require that Asst CP or DO meet the requirements of FAR119. Sometimes it is just a title, but in some bigger operations, the position is used to lower the workload of the principal and ensure that all regulatory items are covered. Sometimes the position is used as a type manager. So don't write off the title without a little more research.
While I understand what you are saying, there is no FAR that requires the experience. If the COMPANY wants to use the requirements, that is fine, but the FSDO has no legal battle according to Part 119. I sick of finding "rules" that FSDOs are using that have no FAR backing them.
Rick1128 has it right on. Since the position is not addressed in the FARs, you can essentially use whatever qualifications you want, as long as your POI/FSDO gives it the okay. They are the ones that approved the company manuals.
CR
Many of the hidden rules that you refer to are actually guidance listed in the 8400 or 8700 FAA handbooks. These guidelines tell your POI how to interpret the FARs. Just because a FAR doesn't address a situation doesn't mean that there aren't guidelines for it. Even though the guidelines are not regs, the FAA will usually treat them as though they are regs.
Not trying to start a pissing match, but I have never come across anything in the 8400, 8700, or any handbook bulletin that has this information. Part 119 lays out the requirements for required personnel and you can get a deviation from those qualifications if needed (and approved). These other positions are company positions and qualifications are set by the company not the FAA. Perhaps I am misled, but I have never seen anything to prove otherwise.
