Flooder305
- Apr 20, 2002
I may be wrong, but my understanding is it works like this. ALPA has access to the pairing generating software, and gets to create different sets of pairings independent from the company. Prior to the bid opening the company can compare ALPA's pairings to their own and see which one would work out best, then that set of pairings gets used for the bid cycle. After bidding closes, ALPA again gets to use the company's commodore 64 to run solutions to be compared against the company's solutions. (There are apparently lots of variables in the award logic that can be changed to affect which trips are assigned first from ones preferences and thus the outcome of the overall solution) The bid solutions are then compared to see which one is best. If for whatever reason the company and ALPA disagree on the definition of "best solution" then the whole coin flip BS takes over.
DING DING DING. If you can hold it, you will get it, right? WRONG. It depends on which "solution" the company chooses to make final. This voodoo system is garbage. I hear guys all the time- " why did it give me that?!!", "why did it throw this two-day on the end of my four-day?!!" "WTF, O."
There is no control, only the illusion..
ASAholes!!!!
You must spent all day on FI to call ASA guy A-Holes on every thread. You're pathetic!
company's commodore 64 .
A-hole
I'm bottom 25% CA ATL and have gotten what I've bid for every month so far. I have training and vacation the last 4 days of next month. I know I can't hold weekends off so bid my training over the 3rd weekend. I work two 4 days next month, last day flying is the 15th. Training starts the 19th-22nd, then the rest of the month off.
So what is all this talk about not having time around training dates? Line bidding... Not a chance.
