skylane58 said:
What kind of requirements? Ones for the airport or the operator? The airport in not required to have ARFF for anything other than scheduled 121. And then it has to do with aircraft length and capacity. Index A airports just have a truck with cab controled turret.
Just a correction on this.
139.315 is Index determination of aircraft rescue and
firefighting equipment requirements.
139 regulations are in regard to airport certification,
which include ARFF requirements as well as numerous
other details pertaining to the airport, lighting, pavement
markings, ect,ect,ect...
139 is not based on 121 operations alone.
The index is determined by a combination of-
1) The length of air carrier expressed in groups; and
2) Average daily departures of air carrier aircraft.
b) For the purpose of Index determination, air carrier aircraft
lengths are grouped as follows (not capacity):
1) Index A includes aircraft less than 90' in length.
2) Index B includes aircraft 90' but less than 126'.
3) Index C includes aircraft 126' but less than 159'.
4) Index D includes aircraft 159' but less than 200'.
5) Index E includes aircraft 200' or greater in length.
There are 2 exceptions to this rule.
1) If there are 5 or more average daily departures of air carrier
aircraft in a single index group serving that airport, the
longest index group with an average of 5 or more departures
is the index required for that airport.
2) If there are less than 5 average departures of air carrier in a
single index group serving that airport, the next lower index from
the longest index group with air carrier aircraft in it is the index
required for the airport.
139.317 deals with the equipment and agent requirement
for each index.
Your carrier (example: Lakes/121/135) may serve Pierre SD.
they don't need firefighters at the airport, just the required
agents on the field. The local Department only needs to show
the airport manager that someone was trained in the communittee to use them, along with hazmat training and basic
first aid.
I used to be a full time firefighter for over 7 years and dusted
off my reg's to find this one.
Airport Firefighters are often refered to as ARFF's.
But when they first start we refered to them as
BARFF's
Basic Air Rescue Firefighters.
